I’m not a huge authority on chef knives or anything, but I will comment on you fit and finish.
The first thing I notice, is that the sanding on your blade is uneven. Near the heel of the blade, the material is darker than the rest of the blade.
Second is that your pins are not quite right. The far right one looks like you had a little break out when you drilled it, or when you pushed the pins in. The front pin has a dark halo around it, indicating that you got it too hot while finishing, or the hole was drilled too big.
I do like the over all shape of the knife, and your makers mark is well etched.
Keep it up!
