First chef's knife and first razor in progress
Brian.Evans
Registered Member
I dropped my carbide faced file guide and snapped one of the carbide pieces, so I had to pause the Dart EDC run while it's off at Bruce Bump's shop getting repaired. Hopefully it will be back tomorrow or Monday. However, I wanted to work on something productive, so I got these rough ground and ready for heat treat. I usually make EDC and general purpose fixed blades, but I wanted to try a couple that were a bit more specialized.
First is about an 8 1/2" chefs knife. 3/32" 52100, right under 2" at the heel. I'm going to be making six more of this pattern once my Dart EDC run is finished, three in 52100 and three in AEB-L.
This is a project I've been working on for quite some time. I partnered with a guy over on Straight Razor Place forum three or four years ago to help me design a straight razor and convert to CAD. This is my first attempt at grinding one of the blanks. I have round nose, square nose, and square nose with a barber's notch patterns ready to be cut. This was ground on a 2" wheel, hopefully I can grind the next one on a 6" or 8" wheel. 0.220" thick A2, 0.850" from spine to edge. Should be right in that 16ish degree inclusive edge angle. The next ones will be in AEB-L or 52100.
Razors and kitchen knives are completely different than regular fixed blades. Even if these don't turn out I'm going to keep plugging along. I've really enjoyed pushing my limits as a maker by trying these.
I'll try to grab some additional pictures when I get home.
Just for fun for those that haven't seen it ;0)
[video=youtube;0GVB0qkRF1c]https://www.youtube.com/watch?v=0GVB0qkRF1c[/video]
I would say that you certainly got the blade profile right on both of them. so far, so good, right? :D Of course, the bad news is that unless you can hammer a few pieces together, you may have wait for Aldo to get his batch of modified 14C28N clone steel in the shop. Even then, the thickest stuff may only be 3/16 which would in theory let you make a 5/8 or maybe 6/8 straight but not nay wider. Aldo was thinking kitchen knives for most of the stuff and folders for the largest size He had not thought about razors which, as you know, typically use steel that most of us would consider the proper thickness for a medium sized bowie knife. ;)
The chef knife looks good. I'm working on one similar right now. I'm gonna give a straight razor a go at some point.
Best of luck on the kitchen knife and I hope you keep us posted either way on your success. This is an area I want to learn as well.
Thanks for posting that. Charlie Lewis is a killer maker. He makes some just insane stuff. Nice guy too.
Yeah.......after I posted that I went to Aldo's site. 0.125" is the thickest he has. Looks like carbon steel it is......52100 or O1, probably 52100.
Most of the guys over at the other site would tell you O1, but I have seen guy do a lot of nice razors using W2, 1084, 1095 and 52100. The razor guys can be funny in that they really aren't big fans of enhanced abrasion resistance because they think it makes honing more difficult. Personally, I would be more concerned about fine edge stability what with all of the chipped and even shattered edges we see on beat up old razors made from toehold higher carbon steels even when they were using very advanced (for the day) HT methods like molten lead. . That says sub 1500F 52100 or W2 to me.
