- Jan 1, 2016
hey guys not trying to post this to down crk or anything. However I purchased an umnumzaan new and the blade came with a recurve in the edge and rather ugly uneven tip. The tip doesn’t bother me as I can reprofile free hand or with a bga ko. The problem is the recurve. I contacted crk and they said that it should go away with normal use. Sorry but any time I’ve has this in the past it doesn’t go away on it’s own...only gets worse.
Now I understand I could put the edge straight to the stone and work the knife from choil to tip and essentially grind the entire edge away until it catches up with the recurve and then reprofile it. Downfall is I lose a ton of metal with this.
I can place the edge against a known flat object and see what appears to be .003 line of light starting about 5/8 from the choil area and extending about an 1.5” toward the belly. I get this measurement because I can slip a piece of phone book paper under the recurve area but not a piece of printer paper.
Seeking advice on what you guys suggest doing. Thanks in advance
