- Aug 5, 2011
It's time to make my own blade out of AEB-L! After watching some videos online i figured i had everything covered and so i asked my father to teach his adult yet unknowing son how to use the angle grinder. Btw, it does matter how you hold the grinder as otherwise you may well end up spraying your face with hot metal (yes true story that one). My father did his best to control his very eager son, yet he didnt touch the grinder even once! Thanks dad.
It started some weeks ago in autocad, i wanted an blade with an straight pommel for the versatility it brings, also i wanted an small fingerguard and also an drop-point for some added strength and the ability to drill a little better (dunno if any of this is true). The Nordanljus BC-4 was born
Nordanljus is northernlight in swedish and BC-4 stands for Bush Craft 4 inch. (and yes i borrowed some well needed blade geometry from the trapper).
Photoshop drawing from autocad blueprint
printed
glued onto the bar of steel
found out there is a correct way of doing things, the old mans way. i traced the outline of the print and changed clamp. the angle grinder is doing good.
roughed out using a cut out and a grinding wheel. !angle grinder love!
roughed out on the belt-sander. Need some kind of 90 degree platform as freehanding it was hard
Next i will grind the blank 100% complete, drill the pinholes and lastly try my hands on some freehand edge grinding.
All in all i had a F R E A K I N G blast and getting to spend some quality time with my dad (though im 25) was incredible!
/Michael
printed
/Michael
