- Mar 26, 2012
I recently completed my first frame lock (..finished product here) and took a ton of pictures during the process. I had a few people ask me to share how it was made, so I thought I would start a thread about it. I figure this will take a few days to complete. And if anyone is interested, I will be glad to share links to the materials and tools that I used, too.
Also, I just wanted to say that its been awhile since Ive posted in this section of Bladeforums. Seems like I lived here in 2012 when I first started making knives. Im a DIY kind of person and enjoy researching a hobby about as much as I do making stuff. Very helpful group of makers here and lots of great info! I always loved finding threads like this where makers would share a glimpse into their process and pictures inside their shops. Im definitely not an expert at this stuff.. not even close, and I made several mistakes during the making of this knife, but I will cover those as I go through the steps. And thats the SOLE PURPOSE of this thread - to encourage new makers or someone who may be considering knife making. Its a hobby.. its meant to be fun. Yes, its challenging, but a rewarding one, I promise.
Thanks for checking it out and I will be glad to answer any questions to best of my ability.
Lets keep it positive!
Shannon
Like a lot of knives that I make, this one also started in Draftsight. Draftsight is handy since you can place the blade on a separate layer than the handle/frame and rotate it on the pivot to check for clearance.
Thinking I would actually make more than one of these, I cut the frame out and glued it to some scrap steel. I cut and profiled the steel to make a template.
Finished template.
I coated a piece of .158 titanium with Dykem layout fluid then clamped the steel template to it using vise grips and traced around the edges with a carbide scribe.
All of the rough cuts are made on this saw attached to a SWAG offroad portaband table.
I also traced the template with a sharpie onto this piece of carbon fiber I picked up from Jantz at Blade Show last year.
Titanium is a tough to work with. I used an old 60grit Blaze belt on an 8 contact wheel.
Starting the profile..
Grinder setup.. this is a welded no-weld grinder plans from usaknifemaker.com
Grinding titanium is a take-it-slow process.. I can only run the grinder at about 20%. The goal is to slow the grinder down to the point where the titanium is no longer sparking. It actually goes faster this way.. kind of hard to grasp the concept until you actually work with the stuff.
Titanium makes quite a mess, so I wet this cloth to collect the shavings.
Finished profile..
Backside. I noticed that it leaves a bit of a sharp edge/overhang on the titanium, especially if it is run too fast.
Switched the belt out to a used 60grit Aluminum Oxide belt for the carbon fiber. Dust collector and mask are definitely used during this process..
Funny.. it took about 15-20 minutes to grind the titanium.. about 2 minutes to profile this piece of carbon fiber.
Finished Ti and CF pieces for the frame.
Titanium is just a little over .158 thick. This came from Alpha Knife Supply.
Carbon fiber is much thicker and I probably should have started out with a thinner piece, but I thin it out later on the surface grinder. I bought it thinking I would use it on a fixed blade.
Shannon
Finished template.
Finished profile..
