Like Ken said you are doing a great job.
Question that is the first I have seen on a wip/tutorial where someone has countersunk the holes unless I missed it on others and a noticed you said important....does it just make the fit up easier or better?
Countersinking holes is normal practice when you want a clean hole. It's not a big countersink, just enough to break the sharp edge. Makes threading and fitting close tolerance pieces together.
Ken H>
It's coming out awesome! I admire you taking the bull by the horns and you're really showing some skill but your lock geometry would be improved if you designed the tang to meet at the outermost edge of your lockbar. The force generated moves at at 90 degrees from a line connecting the center of the pivot and the lock contact. Ideally that force should run as much as possible down the lockbar. I don't know how much difference this actually makes in the real world but I'm just say'n.
I tried to make it two dimensional...
If you imagine the same lines where your lock is now you'll see the force is directed more towards the back of the handle.
Mark
