- Nov 11, 2008
Howdy guys! I did my first grinding on my grizzly 2x72 and some steel i got before the contest. This is just me getting the hang of the grinder. Its kind of wierd trying to hold the back of the blade with ur fore finger as you lower it onto the 10inch contact wheel. The belt is moving so fast it tugs on the blade a bit. I used the work rest and a push stick to try it the Johnny stout way. I made quite a few mistakes and learned alot also. I did the initial hollow grind with 36 grit too 120 then too 600. I was wondering if 120grit is good enough for heat treatment? I doubt i will even heat treat the blade though.
