Nice knife. Simple and with clean lines. Excellent job.
On the next one try this:
1) Make the edge shape and tip location the same.
2) Maker the blade with just a bit of taper.....with the spine line rising from the tip to make a slight angle with the edge line. Do this by increasing the height at the ricasso by around 1/4". You don't need to change another thing on the blade.
3) Make the same handle you did, but taper the handle slightly from the butt to the bolster to match the blade taper, making sure the spine line continues up the handle top as a straight line.
This will raise the handle a bit from the cutting board, and give a bit more "flow" to the whole knife. You should also taper the handle on the sides correspondingly. One great advantage of a hidden tang is the handle can be taken off and on and shaped to as close to final as you wish before the final attachment and buffing.
These small changes will give the entire knife a bit of a "wedge" look optically, and make it more functional as well.
