first let me say I am NOT a knife maker by any means so go easy on me, haha. After seeing a few of the custom knives around, specifically this one, I decided to try my hand at it knowing full well my results may be less than impressive. So I'd like to use this thread as a build log to document my mistakes, and the occasional success.
I should also point out that while I may not be a knife maker, i do run a small prototyping shop from my house so I do have some cool tools. So if you're expecting to see a knife blank made on a belt sander you may want to look away, because this isn't going to be one of those threads.
Naturally I decided to start with difficult materials and attempt to make a frame lock folder. So the blade will be a 1095 based damascus steel with titanium scales. Throw a few ball bearings in the mix and I should have a knife. So lets jump in with almost no for though or planning!
Starting with a damascus blillet that's, uhh, a bit twisted to start with.
no worries, a bit of mill time and we are flat and parallel within .002"
Moving right along, I made a custom fixture to hold everything while machining the actual blade.
there she be right off the mill. Needs a LOT of clean up work.
After Many hours of sanding, it's starting to look like a real blade.
the blade is quite soft at the moment (26-28 HRC) so i'll need to heat treat it as well which means I needed an oven. Lucky break for me I found a little one locally that "worked". Well, turns out 1 of the 4 heating elements is shot, so I'll be fixing the oven as well. I have everything on order to fix it, so hopefully I'll have more news on that in a bit, but here is the oven as it sits:
