- May 18, 2009
Some pictures first:
Triple checking everything
Hand sanding, taking shape
First coat of Enduro-var (4 more to go, after working up to a 4000 grit micromesh pad starting at cheap 60 grit aluminum oxide sandpaper)
Finished, needs final edge work
Messed up pretty noticeably on this side, trying to clean up on the belts after heat treat
View of handle contours, some greenish tone came out in the dark spots of the lignum vitae on this, I really could have done without that happening
My humble shop (garage)
Last month I met with a local maker named Tobin Smith. Here is showing me the basics to heat treating. We spent a lot of time in his shop too and he gave me LOTS of good tips, the wood I used for this knife handle, and a hardened file guide he made for my plunge lines. He is a great guy, he opened up his home to me and my lady and it was one of the best times I've ever had. He makes some of the best looking knives I've seen too.
Here is the biggest mistake in my opinion. I messed up when trying to put the first edge on here.
Some thoughts:
One of the hardest things for me was figuring out how to put an edge on a knife with no real bevel. I can sharpen very well using stones but sharpening on a moving belt is a totally different animal. I tried to match the angle on my spyderco pocket knife.
I don't know if this Enduro-Var is the best option for a knife handle. I went to a local woodworking shop and they recommended it to me. I don't have a buffer/polisher but using this stuff looks like it has been buffed and it feels great.
The lanyard tube was one of the most difficult things for me. It is actually only a friction fit on this knife (will not be in the future on anything I make). I sanded it down in the drill press over and over to thin it out because the 5/16 tubing wouldn't fit through the 5/16 hole. That was quite a pain and took a lot of time.
Using three corby bolts seems like overkill and a waste of material. Also it was hard trying to get all three to line up, should have put more time into measuring but next I will only use 2 for this size knife.
I noticed to get a truly comfortable handle and not a weird blocky feel you have to pay a lot of attention to the angle on the handle material that is near the spine. I spent a lot of time there with a file shaping it to feel more like a barrel like cylinder instead of a slightly rounded block.
Questions:
What is the trick to keeping your spines clean and smooth looking?
When you are grinding a scandi using an angle iron jig/clamp do you get the bevel in one pass or make several passes gradually bring it back to a line you mark? (This was actually a failed scandi, had to revise because the edge was too weak at this angle)
Should I try to find a bit that is just a smidge wider than the 5/16 for the lanyard tubing or ream it slightly out using a dremel?
I used the System Three T-88v Epoxy because I think I remember seeing bladsmith say he uses it. Do you guys actually measure the epoxy parts by weight or just squirt it in side by side and eyeball it?
Thanks for your opinion, suggestions and feedback!
Some thoughts:
Questions:
