Hi all. Finally started on my first knife after months of YouTube and forums. Thank you all for posting the stuff I needed to get started. I decided on a fixed-blade, 9" OAL, full flat grind, basic camp knife. So far so good (more or less), and I have a nicely shaped piece of 440C just about ready for HT (I hope). I would like to ask advice on the following two details before I send my baby off to get scorched:
1) I did not get quite all the mill scaling and pitting from the raw stock completely removed from a portion of the tang. It will not be visible after the handle scales are installed, but my concern is more about the black scale still in the pitting. Will this cause any corrosion to the metal over time, or is it not a problem to just leave it there?
2) I used a filing jig to form the primary bevel. I wanted to be very careful to not go too thin on the edge so as to avoid any HT warping. I think I am good where I stopped, but on closer inspection (of course AFTER I got everything down to 220 grit), I noticed that the edge thickness near the plunge line is a bit thicker than the edge at the tip. Is this going to be a big deal when putting on the final edge and sharpening, or does it need to have a completely uniform thickness from the point to the plunge?
Thanks in advance,
Matt
Thanks in advance,
Matt
