Here are the pictures of my (nearly) complete, first knife. This knife is going to my dad and all I have left to do is run the blade through a scotchbrite belt (once they arrive) to even out the finish and then a final resharpening after all I've put it through.
Here's the info on it:
1080 1/8" x 1 1/2" bar stock from Kelly Cupples.
Triple normalized.
Heat treated in improvised charcoal forge to 1500(ish) and quenched in a little over a gallon and a half of canola oil.
Left the finish that was there following heat treat except for cleaning off decarb. I liked that it looked old and rough.
Handle is made out of a piece of Mahogany and treated w/ 4 coats of Tru-Oil and then two coats of Mothers Brazilian car wax.
<a href="http://s201.photobucket.com/user/wowndeye/media/Mobile%20Uploads/20140531_184217.jpg.html" target="_blank"><img src="http://i201.photobucket.com/albums/aa45/wowndeye/Mobile%20Uploads/20140531_184217.jpg" border="0" alt=" photo 20140531_184217.jpg"/></a>
<a href="http://s201.photobucket.com/user/wowndeye/media/Mobile%20Uploads/20140531_184553.jpg.html" target="_blank"><img src="http://i201.photobucket.com/albums/aa45/wowndeye/Mobile%20Uploads/20140531_184553.jpg" border="0" alt=" photo 20140531_184553.jpg"/></a>
<a href="http://s201.photobucket.com/user/wowndeye/media/Mobile%20Uploads/20140531_184612.jpg.html" target="_blank"><img src="http://i201.photobucket.com/albums/aa45/wowndeye/Mobile%20Uploads/20140531_184612.jpg" border="0" alt=" photo 20140531_184612.jpg"/></a>
<a href="http://s201.photobucket.com/user/wowndeye/media/Mobile%20Uploads/20140531_184627.jpg.html" target="_blank"><img src="http://i201.photobucket.com/albums/aa45/wowndeye/Mobile%20Uploads/20140531_184627.jpg" border="0" alt=" photo 20140531_184627.jpg"/></a>
<a href="http://s201.photobucket.com/user/wowndeye/media/Mobile%20Uploads/20140531_184652.jpg.html" target="_blank"><img src="http://i201.photobucket.com/albums/aa45/wowndeye/Mobile%20Uploads/20140531_184652.jpg" border="0" alt=" photo 20140531_184652.jpg"/></a>
Please share any thoughts/criticisms, I'd be happy to hear them. To be my own worst critic:
Things I became aware of that I know I need to improve on is my grinds. I intended to leave about a 1/8"-3/16" grind line along the top of the blade but due to the learning curve ended up taking the plunge line just shy of the spine, I'm getting better/more control though.
My drill press is a HF 5 speed and doesn't run true which I believe over sized the holes in the wood, or at least made them a little uneven (even though they felt tight) which left a small epoxy ring in a couple spots around the brass pins.
I think my distal taper could have been a little narrower being that the knife is a drop point hunter.
I like the mahogany for the handle but hoped the color would have popped a little more. I had applied some nitrocellulose lacquer to a piece from the same cut which really brought out the color. Another couple coats of Tru-Oil may have helped, but I thought maybe the wax would help. Color does look a little better in real life compared to the pictures.
That's all I've got for now!
Takeaways from this experience (forgive me if I state the obvious for some):
The learning curve for knife making is waaaaayyy steeper than I expected. I have 14 years construction experience, 5 of which were finish carpentry for a Mega Yacht fabricator where I learned a ton about working with different materials, and I'm accustomed to and capable of very detail oriented work, but knives are a whole new world!
I was lured into knife making from an article on Facebook I saw that said you could make a knife from a file, which is entirely possible and I will try at some point, but if you want to produce a quality product and get predictable results, going with a known steel is a wiser way to start.
Each steel has it's own personality and needs to be treated just right to enjoy it's full potential.
Before choosing a steel to work with you have to consider the tools you currently own.
Good results can be obtained from less than ideal/efficient tools, but will require more time/work.
If I want to be rock solid on my heat treats and advance to more particular steels, I need to begin learning and invest in a gas forge and eventually one with a PID.
Play around with different belts, equipment, etc...
Read, read, read and re-read all the stickies/tutorials on this forum and elsewhere.
Be willing to accept your mistakes and if possible work around/adapt to them.
It's not likely that you'll produce a Bob Loveless on your first try, and that's okay!
Anyways, I'm sure there's plenty more but I wanted to say a huge THANK YOU to all the people who invest in all the newcomers here and patiently answer their questions! I'm also grateful for those who ask all the questions and think of things I hadn't thought to ask.*As someone in an earlier post stated, newcomers are producing some pretty good stuff thanks to this group, myself included. I would hate to think what I would have ended up with had I not had this forum. There was much frustration during the process and I'm sure some more to come, but I can't imagine how much I was spared because of everyone's willingness to share their experience here. In fact, I wouldn't have made anything probably because I wouldn't have had a clue where to start. I literally knew nothing about steels prior.*It was because of browsing through here that I gained the confidence that if I made this attempt, I could actually produce a functional knife.
All frustrations and setbacks aside, I've had a blast learning and think I'm hooked! I don't know how many knives I'll make and how far I'll go but I think I'll be around for a while!
Thank you all again!
Triple normalized.
