- May 9, 2000
Your first knife looks a lot better than your first sheath. All in all though, you did a good job.
I can't tell for sure from the photos, is it full flat ground or is it a short grind that goes up at about 1/4"? If it's the latter, I'll give my same old boring advice to take it higher, a lot higher. Also, you will want to work on sanding to higher grits on the grinder, the low grit scratches are fairly prevalent.
Wet sanding the micarta up to about 400 will take out a lot of the "dirty" look, also buffing with a loose buff and green or white rouge after wet sanding.
I also like the handle shape, I do feel a little bit like it is a knife that wanted to be a dagger and only got one side ground.
