- Nov 29, 2016
Hi all just wanted to share my excitement
After some good advice on a forum here about using some old mahogany for handle scales I finally got it done. Like so many before me I started with an old file for my steel. I was lucky enough to have someone heat treat professionally for me and even with this mystery steel it has worked well and is holding a good sharp working edge.
The most expensive materials were the epoxy and pins because steel and wood were from my own scrap.
Mahogany handle finished with Danish oil. Knife all hand filed (hard slog) as I don't have a grinder other than a really cheap bench grinder and an angle grinder. I also don't have a drill press so hand drilling I think I got one of the pins holes a bit funky. Need suggestions for that please.
Anyway, enough of the excuses.
I took the grind all the way through to the back of the blade because the file was a real thick old beast of a thing and I wanted to reduce it. I'm now working on my next knife out of 01 steel billet so won't have that issue again.
Cheers Martin
Sent from my SM-G920F using Tapatalk
Cheers Martin
