I like the profile of that blade. You have a good sense of style with that one. Your grinding appears to be coming along. In those second pics I can definitely see you have the right idea. Here are a few things that help me to grind with more consistency:
Try to keep your elbows locked in at your sides and grind evenly with a rocking motion at the hips. Don't "poke and look" a lot. Try to take a full length, even, fairly light pass from plunge to point , then observe the results.
Once you get a good flat pass established by adjusting your angle, bring the blade to the belt every time with a somewhat "loose" grip so that the blade instantly self adjusts to the flat you already have established. Doing this so that the edge is very slightly leaned into the belt when you first make contact will save the spine side of the grind (which is much harder to correct) from a lot of dings and grinding mistakes.
Grind the edge with a 45 degree bevel almost down to the desired edge thickness, nice and straight, then with intermediate flats work the grind up towards the spine. You can rough grind your plunges in and leave a little room for cleaning them up with a finer belt, grind most of the blade and then you can push your plunges back a little with a sharp 220 belt, also working on keeping them even and shaping the radius at the top corners of the plunges/grind line.
This works best with a flexible belt such as a J-Flex, (not sure what's available in 1x42) which you can track over the edge of the platen a little so that it folds around the edge. It helps this process a little to break in the edge of the belt a bit by applying the corner of an old file or something to the edge of the belt while it is running.
There's nothing wrong with filing in plunges, it's a smart idea, but it's really worthwhile to develop good freehand grinding skills and don't be discouraged if you make mistakes while learning. It's unavoidable. Hope any of this helped.
