- Jun 20, 2009
Here is a WIP thread I am starting With great thanks to Nathan and Bill. I have received alot of great stuff from Nathan including: 0-1 steel, black linen micarta and pin stock. And I have gotten instruction from Bill Burke on how to grind a knife into a great mellow convex edge.
I learned on Bill's Burr King, which is incredible. I need to get my own 2x72. I can definitely tell all the nubies that if you can afford it, buy or make a 2x72 grinder. the 2x42 craftsman does not work anywhere as easily as the 2x72 Burr King.
So here goes, I made four designs: i am going to use #3 in the first pic. ITs a design of a knife i already have. It is a great design but the handle is too short and the blade steel is lacking .
The second pic is of course the profile pic. I modified the handle a little bit after handling the blade blank to accommodate my blocky hands and stumpy fingers.
The third and fourth pics are of my first attempt at grinding with my temperamental 2x42 craftsman grinder that is way too fast. If you look close there is a small dark spot at the bottom of the blade to the left of the middle at the edge. I think that is caused by the grinder speed being too fast and difficult to handle. The spot is not an overheat spot but where too much material is taken off. During my practicing on so flat bar steel from Lowes, I noticed the same problem at the exact same spot. The edge may be too thin in spots(.020) for the pre heat treat but I think I can just shave a little off the edge. I haven't quite got the grind technique down on my 2x42. Like I sad, it is very difficult with that machine. and as you can tell by the pics that the grind is very uneven and needs work. I am going to have to get together with Bill Burke again soon. Ide like to finish this knife before the 23rd of December because I would like to show my family when the arrive for the holidays...My fingers will be crossed.
Please let me know what you think. and and all opnions/advise welcome.
Thank You Nathan and Bill.. without you two I would be spinning around in circles chasing my tail.
