Hi all,
I'm planning on giving my brother a knife for Christmas with a handle made from the antler of a deer we killed last year. I also plan to make one for myself from the other tine. Since this will be my first cutlery attempt, I have many questions.
I am going to use a hidden tang blade. I've picked out the blade I'm going to use for his. For my own though, I'm in a bit of a quandary. I wish to make a carbon steel (1095) skinner. However, I can't find anything like that online. Anyone know a source?
Secondly, a question or two about the antlers themselves. The rack is pretty small. Where I plan to cut it's oval in cross section, maybe 1" in diameter along the long axis and 1/2" along the short axis. Will this be enough to support a knife that is to be used, or do I need to resign myself to keepsakes?
The antlers also have quite a bend in them. I don't plan on straightening it if I can avoid it. What length of tang do I reasonably need in the handle? Can I bend the tang under heat? However, should it be required that I straighten the antler (using the boiling and vise method), how long must it dry in the vise before assembling the knife?
A related question: if I can bend the tang and sink it further into the handle, what tool works well to hollow out the channel since I wont be able to drill deeply?
Can anyone recommend a readily-available epoxy?
Lastly, I like the look of the cast guards but I'm wondering how easily they will mate up with the antler. Are they easy enough to shape and finish? Otherwise I will use a flat guard.
Thanks in advance. I'm flying a bit blind here, since the idea just hit me today.
Dan
Dan
