Cody does what I do, pretty much. I use a piece of thick steel (1/4") that is about the length of the knife. Using C clamps, clamp one end of the steel onto the end of the tang tight, clamp the other C clamp near the blade tip. The bar of steel should be on the right side, if the blade is bent to the left. Place a small nail right at the apex of your bow/bend, and then tighten the C clamp to where the bow is bent about the same amount, only in the opposite direction. Sight down the blade and make sure that you didn't ADD any bends by your C clamps, make sure the only bend is the bow being corrected in the opposite direction. You may need to scoot one or both C clamps up/down the blade to get things just right. It is nice to have a wife or buddy nearby to lend a third or fourth hand, as you're trying to fiddle with 5 things at once. Blade, C clamp, C clamp, steel bar, nail. Concerning the water quench, I think the idea behind that is to try and "set" the correction, but I'm apprehensive if it does anything. I just turn the oven off and let the whole thing cool to room temp before checking. Usually, just one time is all it takes, but you can do it as many times as you like. 400F is about the minimum temp for this process. One thing I have found out....if you get the blade nice and straight, but realize that it' still too hard and needs a higher temper, the bow will come back if you temper the knife at a higher temp than your last run, and you'll need to straighten it again.
