First rule: Never push on a blade to break it, you can end up hurting yourself, always pull and you fall free. Always wear safety glasses and plan that if it breaks you will not fall into something that can hurt you.
You never know what that truck spring is made of, some springs are of good steel, others are full of faults. You chase an invisable foe when you do not know the quality of the steel you are using.
I wish you lived close to the Willow Bow, your enthusiasm impresses me, would love to teach you how to forge, harden and temper a great blade.
In the mean time, keep on with your experimenting.
A few questions: What is your quenching medium?
How hot do you work your steel?
And a comment: The 450 temper should have been plenty. If you want to continue to work with that steel, be sure it is free of surface faults ie. scratches or dents.
Rex just did some hardening experiments in his Lab. with multiple quench:
Watching the steel cycle down through the phaze change,
1 st quench time 15 seconds
2 nd quench, time 10 seconds
3rd quench, time 2 seconds.
tempering temperatures, increasing 15 degrees for each cycle through the three samples Resulted in an increase of 20,000 psi strength.
