YESTERDAY was looking good. Vinegar/soap etching as prescribed by Nick.
Post vinegar etch had seemingly great results. This is after the third round of etching. Personally, I think it's a good looking hamon line (it's the first I've seen at this step, haha)
AAAAAAAANNNDDD Post polish after third round of polishing...almost no hamon, but it is there in the right light. You can just barely see it just below the bevel....little did I know, I should have stopped here and went on to my handle.
TODAY was anything but satisfying.
I soaked the blade in ferric chloride mixed with water (3:1 water:fc) for approximately 4-5 minutes. Things seemed fairly promising, I could see a good hamon line in there.
I started polishing the blade with the 2000 grit and the frustration slowly grew. I shortly found out that I was dealing with what seemed like a whole new layer of scaling. There was [is] rust like pitting all over it. After 2 hours of sanding away on one side with 2000 grit and watching what little hamon I had, slowly disappear, I had to back off to 1200 grit to get the new unwanted texture out. 1 hour at 1200 grit, and another hour at 2000 grit. The pitting is still there and I want to throw the damn thing in the neighbor's yard. I have no idea what's going on...just posting about it pisses me off all over again.
Going to back down to 600 grit tomorrow, 1200, 2000, then 4000 to finish it up. Screw the hamon at this point, it's my first knife and I just want to get to the handle. Maybe I can get my wife to use it in the kitchen and some sort of hamon will develop over time.
Forge WIP pics on the side...
Just one very thin layer of satanite right now, to get the inswool to stick where I want it. I torched it a little to harden it, it's going to air dry till saturday, then I'll add more to get it to the required 1/4" inch, then I'll get the ITC-100 on there and harden that up. I have a 1" fire brick for the bottom shelf, it is lined up right now to be dead even with the bottom of the front door...oh and I also need to get the door insulated. I'll probably use double sided foam tape to get the inswool sticking to the door, then the satanite should cover it well enough to make a nice little egg shell to keep it all on. I wanted to make sure ALL the inswool was covered at least some, I DO NOT WANT ANY CHANCE TO EVER BREATHE THIS STUFF IN. Some got on my skin when I was measuring and cutting, and I broke out in hives...not fun.
Alden added the door shelf, the handle rod, the burner pipe and welded the door on. POW!!! Alden is the MAN!!! I only wanted help with lining up the burner pipe, but he just kept going...Possibly the nicest guy I've met. A fire brick fits on the shelf perfectly.
