Ok, I am making my first knife out of an old rusty file. I have used a bench grinder and cold water to shape it into a tanto blade. However, I have run into a few problems. The is going to be a folding knife, and I want to either use a liner or frame lock because of how simple these mechanisms seem to be to make. I am leaning towards the frame lock because it is more durable than the liner.
Questions:
1) I have a drill press, but what size bit should I use, and what material drill bit should I use to drill the pivot pin's hole?
2) Will some thick sheet metal work well for making the handle/framelock?
3) What should I use for the pivot pin?
4) What size should the stop pin be, and should it be a screw or a piece of an old drill bit?
5) Is there anything I should know?
I know, I should've started with a fixed blade, but the truth is, I prefer folders, and would never use a fixed blade anyways.
Thanks,
Guilo
Questions:
Thanks,
Guilo
