Use your kiln for normalizing and thermal cycling.
Normalize temp by the book for 1095 is 1600F, equalize, air cool. 1600°F-1650°F OK.
Thermal cycle: 1500F, equalize, air cool, 3 times (you can also do descending heats, as in 1500F, 1475F, 1450F) Usually 3 cycles is good enough. Just remember that excessive thermal cycling lowers the hardenability of a steel, and 1095 is already shallow hardening. I like to stay above 1414°F (and well above 1350°F) for thermal cycles, preferably ~1450°F-1500°F. Below 1350°F is spheroidizing temps; 1350°F-1414°F is where the austenite phase transformation is started, but not complete; "critical temp" of the steel is where thermal cycling for grain refinement is best done; thermal cycling above critical is fine as long as the temp is low enough close to critical; and cycling above ~1525°F-1550°F gets into normalizing (grain growth) temps again.
For all hypereutectoid steels during normalizing, cycling, and hardening, I employ a soak of 10 minutes rather than simply "equalize". Some do, some don't. For such a low alloy steel like 1095, it probably isn't as critical as soaking steels higher in alloy like O1 or 52100.
