- Jan 6, 2016
I was bitten by the knife bug about a year ago and started making knives around then, but I only recently decided to try a hamon. I applied the "clay" (Commercial grade quikrete fireplace mortar) that I got at home depot, I let it dry for 36 hours, and I quenched it like I normally do. I am using 1084 (I know this isn't the best steel for a hamon but this is the best I have available) that I purchased from Knifemaker.ca. After cleaning off most of the clay remnants and oil left on the blade, I tested the blade with my brand new grizzly hrc files and the spine was WAY softer than the edge. I stuck it in my toaster oven at 400 degrees for an hour and test the hardness with my files and it was the exact same. After roughly another hour I tested it and still had the same results. I think I am at 3 hours now and my 65 hrc file still skates on the edge like it just came out of the oil. By now the edge almost looks purple while the flat of the blade is straw colored. I can see one of three things that could be happening; my files could be junk, I could be going insane, or something way beyond my limited metallurgical knowledge happened as the blade was quenched. I have only had this happen to one other blade before and I kind of just gave up on that one because I thought it was just some weird occurrence. I would appreciate any help that you guys can provide as I have no idea what to do in this situation. If possible, I would prefer to not heat treat it again because I have difficulties keeping the clay on the blade during the process. Anything helps.
PS: I will try to include a link to some ugly photos of what I am talking about, but if it doesn't work or if you can see all of my photos on google drive please let me know. Also, is it normal to see the exact shape the clay was in without doing much hand sanding?
Thanks,
Erik Nenzen
https://drive.google.com/file/d/0B1a2ctiSJAqrRU1WVW0tb2swR28/view?usp=sharing
https://drive.google.com/file/d/0B1a2ctiSJAqrQnBJV1lvX3FfbWc/view?usp=sharing
Thanks,
Erik Nenzen
