Hi knifenut,
Thank you so much for taking the time to watch my videos. I know you put a lot of real thought into addressing all the questions I asked and to addressing other areas, as well, and I really, really appreciate it.
I’ve already read through your response several times and will be reading it more.
I definitely should be inspecting more often (every 5-10 strokes and then switch, as you mentioned) and not spending any more time than I need to on a stone. Otherwise I’m just wasting my time (and wearing out my stone) as well as working for too long on one side. Thank you for pointing that out!
Your assessment of the deburring block sounds good. If I’m using the stones correctly and correctly apexing the edge, I shouldn’t need to drag it through a deburring block, at all.
You asked about the specks in the green 1K stone. They weren’t blue, they were like… light colored and dark colored, too. But they seem to have sort of disappeared after using the stone. I dunno.
You mentioned that harder metals and carbon steels tend to produce a lot of mud with minimal to no loading on the 1K stone. Thanks for the heads-up and advice. I will definitely be using this stone for different steels in the future, and that helps a lot to know.
You mentioned that I should do more edge trailing strokes at the finish and not switch back to leading strokes. I did do that a lot, I realize. I think I wasn’t satisfied after the edge-trailing strokes, and in retrospect, it’s probably because I didn’t lighten my pressure and finish the general sharpening before moving on the edge-trailing. I’ll be more careful about that in the next sharpening I do.
You advice and thoughts on using the 6K are worth gold. Thank you for this! I was wondering about so many things while I was using it, and you’ve addressed them all and added more points that I didn’t even think about, although now that you mention them, I have seen them before in your videos. I just forgot about them while I was sharpening. I will keep the same slurry for the whole sharpening, just adding drops of water to keep it from drying out. And I will inspect more often to make sure I’m not wasting my time (or my stone). I realize now that by rebuilding the slurry so many times, I was defeating the entire point of building a slurry (which I actually talked about in the video, doh!), which is to let it break down through the sharpening and refine the edge more.
If you don’t mind, I’ve got a few more questions!
1. For the next sharpening, I’ll be sure to not keep splashing water on the 1K stone. I think what you're saying is that since the stone is underwater all the time, just taking it out of its bath will ensure it is plenty “wet” for the whole sharpening. Am I correctly interpreting that?
2. You mentioned that because of the steel being sharpened being a fairly soft stainless, I could use a synthetic nagura to start a slurry to prevent loading to some degree on the 1k. I’m guessing you don’t foresee that being a problem, but you are mentioning it just so that I keep it in mind in case. Am I correctly interpreting that?
3. You mentioned that simply starting at the tip can make it difficult to acquire the correct angle because with the last macro shot I had a micro-bevel to one side. I noticed this, too, even during sharpening, and you can hear me in the vid saying out loud, “Oh, that was too high!” You mentioned the MC style where he drags to the tip then flows to the heel on his edge-trailing strokes. I couldn’t visualize that, so I actually went back and watched it on his DVDs. But he also starts at the tip, so I’m not visualizing. Do you have time to make a video?
Thanks a million again for taking the time to watch my videos and write such a thoughtful response!
Cheers,
Mag
