BluntCut MetalWorks
- Apr 28, 2012
I've noticed he doesn't use the 'S' move all the time and figured it was to prevent the grind path from becoming parallel or reverse to the cutting edge - as will happen at the tip/belly when edge trailing, esp if you normally keep the edge at an angle to the grind/polish path. In his straight razor video he doesn't use the 'S' at all to speak of. In his "push cutting toilet paper" vid you can see what I'm describing. The 'Outdoor' model he's sharpening only has a little belly = smaller 'S'. Contrast that with this demo - you can see it very clearly at about 2.5 minutes, using a knife with a little more belly = larger S.
http://www.youtube.com/watch?v=5stV_1kID-U
At least I'm pretty sure that's what I'm seeing - hope so 'cause that's how I do it...
It makes a big difference on blades with a lot of curve - more consistent edge all the way to the tip. I barely use it all on knives like Mora and others with a shallow belly, have to really exaggerate on things like Bolo or Panga pattern machetes.
:thumbup: this is skill forming.
I'm thinking outloud with constructive intention.
Skill = what+why+how.
e.g. for the 's' stroke
'how'=no s, small s, big s + pressure @ grit -> incomplete
'what'=taken place, interaction (sharpening/honing/lapping/polishing) -> incomplete
'why'=prevent the grind...+follow the belly... however ain't so sure eh -> incomplete
This thread presents many good techniques(a set of 'how') + experiences. Add 'what'+'why' explanation, which lead to permanent skills. I afraid the complex interaction between blade vs [embeded abrasives, loose abrasives, swarf, pressure, edge trail+lead,...] deem quite voodoo outside of the sharpner-knut world.
