Gary W. Graley
“Imagination is more important than knowledge"
- Mar 2, 1999
Very cool indeed, and lovely work on the scales too !!!
I'd recommend allowing a little more room along the edges, just a bit, it will make it easier to finish them better and in years to come, if it needs, you would have a bit more rework area if you wanted to sand them down to freshen them up a little. PLUS when go to do another sheath, that wider area will glue up better and be a stronger more stable piece of leather that will take your hole settings better, won't move around on you. It just makes everything a little easier, then you can trim it off once it's stitched up, like on this sheath I made for a Sebenza;
afterwards I sanded the side and also the edges to make them smooth, you can do that with sanding paper, taped down on a table top, just keep moving up in grits and then some burnishing to smooth the fibers down even more.
As Ken said, keep on bending that leather!!
G2
G2
