Good looking blades! Especially for the tools you are using. I love the craftmanship that appears when someone really wants to make a knife with just what they have.
You want to add wood chips into the pipe with the knife. Just a few should do. As I understand it, as the wood starts to burn, they will use up the oxygen in the pipe and help prevent too much decarbonization of the steel and decrease the amount of scale that builds up. It is ok to force air into the fire to heat it up, and the wood will help use up the oxygen in the pipe.
Basically, as I read it once, carbon is like a man that is really attracted to oxygen, and it will run off with the first oxygen hooker that heads its way. When your steel gets really hot, the carbon is in a free enough form that it can actually be burned out of the blade and ruin your steel. Oxygen speeds up this process so you want to limit oxygen around the blade when heating to keep as much carbon in the steel as possible.
Hope this helps!
--nathan
