First work in the new shop! (with pictures!)
So, Butch just left here a bit ago after doing some banging and smashing in the new shop. Right now what I have is a temporary hot work area set up in a corner of the building since my Mom will be using a good hunk of the shop for some storage for a little while (she's moving). I did manage to carve out a little corner for now and get the anvil, forge, and new Kerrihard hammer in.
Here's a pic of the forging area as it is now:
The forge is a blown gas forge by Darren Ellis, the anvil is a 335lb Euroanvil, the power hammer is a 30# Kerrihard, and the handtruck is a work holder until I get a proper one built :) Oh, and the base the power hammer is on is VERY temporary. I lagged it to some 4"x6" scraps I had laying around so provide some cushion for the floor and to raise the anvil a bit. It will ge a proper base as soon as I get a load of longer 4"x6" cuttoffs dropped off by the contractor down the street.
Here's a better shot of the forge:
We ended up swapping the leaf blower to try the smaller blower I couldn't get working right before...I was giving it too much gas. We ended up getting to 2300+ degrees with a MUCH smaller blower. And, SAFETY FIRST! We made sure the gas bottle was tied to the building "just in case" :)
Sadly, running the forge and the power hammer at the same time resulted in popping the breaker on the one circuit I have strung via extension cord at the moment. I need another extension cord! :grumpy:
So, Butch set to working down a piece of 1" round W-1:
Once we played around a bit, swapped blowers and got a good heat w/ the smaller blower, I took a couple of pieces of 1050 and tried to weld them together. We had welding heat! (I nuked the weld on purpose to see how well it had set on the first set of blows...hitting it sideways wasn't enouigh to unstick it...since it was 1050 I figured I'd see if dunking it in water would do it...the water warped it and popped the weld...nothing shocking)
Then I remembered the pyrometer and checked the heat at the rear of the forge. 2300+ degrees! Well, that meant it was time for me to get a stack of 1084/15n20 I had welded up earlier into the forge.
I took it throgh a few heats at welding temp, making sure to brush and re-flux each time. those 7 layers are good and stuck! I even worked it down a little sideways to be sure. First pattern welded billet here we come! (At this point I'd like to thank Bruce Bump for trading me some steel so I could have some 15n20 to work with... THANKS BRUCE! :D)
We were losing daylight, and there are no lights in the shop, so after a little more forging on the W-1, we called it a day. If there were lights I'd have turned Butch into a power hammer to draw that billet out for sure! I'm going to grind down one side of the billet tomorrow just to check my welds, but I'm certain everything worked just right. I'll post pics of it ground and possibly lightly etched tomorrow. I'm pretty sure though that making Damascus will be like smoking crack....I really need something to attach the leg vise to so we can work a twist....
I leave you for today with a pic of me waving my orange flag of forge welding vistory...Or at least that what I'm calling the crazy motion blur on this one...
I'm gonna be up early and forgin' tomorrow!
-d
If this is just a start, then you are going to have a great shop!!! I like that hammer:thumbup: !! Do you mind me asking were you found it and what was the cost??
All I can say is, I am jealous as hell, but very happy for you! :D Have a ton of fun in your new shop! Thanks for posting those cool pics. -Matt-
I found it on Ebay honestly. It was part of an entire blacksmith shop that was being sold. It turned out that the gentleman who bought it didn't want some of the heavy stuff (since he had to truck it from PA to TX) including a screw press and that hammer. A friend of mine wanted the press and I conned him into picking up the hammer for me while he was there. Including gas $$ to him I got it for $850. It needs some TLC so I figure I'll have a few hundred more $$ into it eventually. For now, it works so I'm happy :)
-d
turn me into a power hammer :rolleyes:
i know now i need to get that 16Lb hammer :D
yes i can see this turnign into "crack" real quick
butch
Lookin Good. After the December show I should have some time......Can I come and play.
Larry
Sure! I'll need some help figuring out proper heat ranges for forging D2 and I figure you're just the guy to ask. I have a piece about 1"x1 1/2"x12" that I'll need to find something to do with. It's too small for power hammer dies :)
-d
Got the hammer runnin today and it promptly let the magic smoke out of it's motor (now I know why it was popping the breaker :rolleyes:). Thankfully I had another motor of the same output and frame type to swap in. I am pretty sure this hammer would prefer a 1HP motor over the 1/2HP it has now though. I can stall the 1/2HP one if I mash the treadle too hard. It'll work if I'm careful, which is what I'll have to to do for now. When its' running it sure helps though :D I'm going to weld up a second billet so that I can work one while I reheat the other.
Back out to the shop! :)
-d
WOW-nice pics-and a nice clean work space-I bet if you have an open invite a bunch of us can get it nice and dirty for ya:D
You have the makings of a nice shop, but you are in dire need of some good old fashioned bladesmith CLUTTER!!!!:D Here is the dumbass question of the day. Where do you get a 100 lb propane tank filled? Do you have to cart it down to the gas company or will they come swap it out for you? I am getting a new and all-powerful forge that will put my NC knifemaker on the bench and 20 lbs grill bottles ain't gonna cut it any more. Problem is that a 100 lb propane tank will not easily fit into the 3 series BMW or an old Porsche 911:D
You're clearly missing the good old fashioned tool haulin' truck! :) Would a 40lb tank do it? You'd have better luck fitting that into your available vehicles. What kind of forge are you getting that you expect to have eat so much gas? I gotta say I highly recommend a blown forge from Darren Ellis. I was forge welding today at 5psi and forging at 3psi.
All that being said, you might be able to get a gas company to deliver LP, but they'll likely either want to lease you a tank or charge you a yearly inspection fee for your tank. Just remember that if you are carrying LP bottles around full that you should carry them upright.
Make sure you post pics of your new forge!
-d
hey dek since i couldnt get my but out there how bout some more pictures
like of that steel you been working
did you test etch it yet
