As already mentioned, here in Australia handling is still really common. I learnt to fish with a handline (used to be able to get a rigged up plastic spool from almost every gas station for under $2) and nothing is quite like it. If the fish are less than a foot long (and a lot of the "bread and butter" fish are) I prefer the handline if I dont have to cast more than 15 yards. The feel is much better. But I find it impossible to handline with lures.
Tips? Same as using a rod/pole. Let the fish nibble and strike when you feel the weight of the fish or see the line run rather then a tug. If you can fish with a pole, you'll do fine with a handline.
For larger fish people used to used gloves so the line didn't cut or burn their hands.
BTW a great hobo real (much better than a can IMO) is a soft drink bottle. The centre-taper shape allows good casting and line holding, while the neck makes a good handle.
Good luck
Chris
Not a bad idea - how's the casting with the tapered center?
A long cane pole with a similar length of line attached to it would do well also but wouldn't work well at all with anything more than a bluegill depending on the size of the pole you are using and your knot skills.
I'll just have to disagree too. Though, its true that your knot skills are important at the hook end and at the attachment end. I've never run the line down the pole like Runningboar has. I start with a clove hitch, wrap the line around the tip several times, and clove hitch again. Much the same as any lashing project. I've cought catfish, bream, crappy, and bass with a cane pole very efficiently.
BTW, if you consider yourself an outdoorsman and you can't tie a clove hitch, I'm laughing at you, and distancing myself from you in a survival situation.
I've ate a lot of catfish that would disagree.
When cane poling, or swarp fishing as my grandpa called it, the line is not just tied to the end of the pole, it is wrapped up the pole from the handle and tied off at the tip. Chris
how do you cast a handline?? it would seem you have to unravel it and than throw it?? pardon my inexperience in this field...
I'm certain fishing bores could elaborate on knots ad absurdum but it is not necessary.
I guess I am a "fishing bore" but I definitely think you need a few more knots in your repertoire than just the improved clinch. Chris
Thats the knot I use.
No offense or anything Myright. Who gets offended talking about fishing! I always wonder at Les, and Bear for not setting up a shelter near a good spot, and fishing the days away.
Ok dude, I'll bite ;-)
For when? I can think of joining two pieces of line, that's why I mentioned the blood knots, but given the context we are speaking of where does the necessity for anything else lay?
Before it was banned in BC i used to handline as a kid/teen all the time. I'd wrap the line (about 8 - 10') around a short 6" stick, tie it off (this becomes the handle - fishline cuts hurt otherwise). I'd attach a float and a splitshot and the hook, cast it out, wait for the bobber to drop and yank, then walk up onto the bank with the fish
There is nothing to bite, I am not trolling, I don't like the blood knot but much prefer the double surgeons knot, much easier to tie and works great for joining two lines or adding tippet to your leader. I also like the palomar better than the clinch if your hook eye is large enough, for small eyes, like on flys, I used the improved clinch or the trilene knot, the surgeons loop along with the dropper loop are also very handy. If you fish with circle hooks or ever have to fashion your own hooks without an eye the snell knot is invaluable. All of these are very simple and very basic, anyone can learn to tie them very quickly. Ad nauseum
The improved clinch is probably the most basic and well known fishing knot but there are much better knots out there. Chris
