I have one and have found it to be a good cutter, with pretty aggressive teeth.
I actually bent the blade on one of the older Gerber/fiskars folders on some very hard wood. But I have not had that with the slide outs mabey because the blade is shorter.
I have heard that Silky saws are better but I have no experience with them.
I have a new one but have not been out to try it out. I am a big fan of little saws. The Silky is probably the best of the best. I have tried almost all of them.
Pit, they are a bit more blunt at the tip. The Bahco seems similar to many other folding versions on the market. The Fiskars is only 21.95 Cdn regular price at Canadian Tire....so a bit cheaper than the Bahco.
I will go check out the Silky version...good online place to check them out???
I have both the Fiskars and a Silky 170. While the Silky is the better cutter, it is also more than twice as heavy. The Silky weighs 7.3 oz. The Fiskars is just a tad over 3. If I KNOW I'm going to need a saw, I'll carry the Silky. Otherwise, the Fiskars is what goes in the pack. It's a very good saw.
I haven't really noticed a huge difference in the way they cut...they all work well.
I can't recall exactly how much I paid for them,but I don't think any of them were more than $30.00.
IIRC the Fiskars was around $15.00.
There is an obvious size & weight difference among these saws,but I carry any of them in my pocket & really don't notice them there.
I took the Silky pictured above and the Bacho Out to the shop. I took a limb that I had cut off of a ash tree and put it in the vice, I took the Silky and cut through it in 20 strokes. I then went a few inches up the limb and cut it with the Bacho. I tried to use about the same weight and length of stoke the Bacho cut it in 27 strokes. Both were good clean cuts and while thew Silky cut with a few less strokes and the Bacho cut with a bit less effort. Neither took much effort at all. There are some good saws out there and the two I tried are amoung the best. I plan to do a test and review of about ten of these saws very shortly and will post pictures and results.
Don't hold me to this but I think My silky is the 170. I don't have it right handy to check.
The slide saw is a good cutter and works well, but the screw/unscrew sliding action is rather slow compared to a classic folding saw. I'd rather get a Bahco.
