Fiskers hatchet - I'm a believer
I'll keep at old no-name with the bastard file. But golly it is taking a lot of time.
Oh man, it is going to take a lot of time that way. Well at least now you know that it's easier to keep an edge on it than to have to grind one back on...
Dang it, this thread couldn't have come at a worse time. I was planning on running to the hardware store today, and now I have this odd urge to buy a Fiskars while I'm there. I'm sure the wife will talk some sense into me though.
Stingray 4540
It is spring, so you will need both a fiskers hatchet and a folding pruning saw. Goodness knows that there are some trees in your yard that are just in aweful condition!
Might be a good idea to pick up some wet/dry sand paper in 400, 800, 1000 and 2000 grit too.....Oh yeah I see some really nice work gloves and a good 100' of 3/4" poly rope in your future....Can't resist some of them carbiners....How is your mini-mag LED light looking these days????? Did you have enough batteries for everything? Hmm there is a little roll of Jute twine for only $2.50....Firesteel, I never knew this store carried firesteel....Is that some fatwood over there?
Oh boy.....hardware store..... :) :) :)
On the chipping edges... I have found that the edge one of mine chipped the first couple of times I had it out. Once I started sharpening out the chips, I have had ZERO problems with chipping.
When I was grinding the bevels flat, the teflon coating made it very obvious that there are a lot of grooves running parallel to the edge. As I understand it, this can seriously weaken the blade. I ground these out of mine before I put the hatchet in service, and I haven't had any problems with edge retention, even when I was whacking away at a piece of old seasoned wood I couldn't get any real penetration on. That thing was hard as hell, and it's not because my hatchet wasn't sharp.
The teflon coating looks cool, but I suspect they also apply it to hide flaws in the blades. The bevel was not pretty looking underneath, but was a whole lot nicer by the time I finished.
Dremel tool with little mini sanding drums works great for that. A few files and the Dremel are mostly how i reprofiled two of my no-name hatchets. Just don't go crazy with the high rpms.
Canadian Tire has their economy brand Jobmate Dremels on sale regularly. Recently they had the combo kit (jobmate dremel and accessories) for 20$!(might still be on sale).
You might need to buy some extra little sandpaper drums though. But they often have the separate accessory-only kits on sale as well.
Wont a dremel draw the temper?
I do have one of the mastercraft knock-offs somewhere.....
Not if you keep the rpms low enough. Basically if the head starts to feel hot to the touch stop for a while and let it cool down.
A lot of people here have used large belt and drum sanders to reprofile/regrind knives and axes without any problems.
Just remember to take it slow and stop if the axe head gets hot.
Even if you want to stick with files the little drum sander can be great for polishing out scratches and blemishes.
The first axe i reprofiled was about 50% done with files and 50% dremel. The second one was done mostly (80%) with the dremel.
You should check on the price of the little sandpaper drums. The last time i bought a batch of dremel brand drum they were about 5-7$ per pack of 5.
Canadian tire also has those jobmate accessory packs with drums/cutting wheels etc.
They were on sale recently for around 12$, they had about 20 drums of various grits included and tonnes of other goodies included.
The jobmate drums don't last as long but they are substantially cheaper than dremel brand.
Remember to wear safety goggles as i have seen the cheap sandpaper drums occasionally disintegrate while spinning.
Basically using the dremel is faster and less strenuous than using the files.
And files aren't cheap either. I just about wore out two files reprofiling the first axe (it had an insanely thick cutting edge).
Thats ok though as i plan on trying the greenpete (youtube) method to make those worn files into knife blades!
:D
Oh yeah a bench vise is great for holding the head while you are working on it.
I put my Fiscars through the ultimate test recently; I let my brother use it! This may mean nothing to most of you but it speaks greatly for how tough the hatchet is. I won't say it's indestructible but it may be close. I did get lucky enough to pick up a sharpshooter sheath for mine that I really like.
those hatchets have the wrong type of edge, Mine did the same thing after I used it, but after I ground the shoulder off , and gave it good convex edge it was fine.
