Nathan the Machinist
KnifeMaker / Machinist / Evil Genius
Moderator
- Feb 13, 2007
The Field Knife was designed as a collaboration with Lorien Arnold. It is a well made, no frills, high performance utility knife. The steel is Crucible CPM 3V at HRC 61-62 with a tweaked heat treat with very good edge retention and edge stability. You'll be surprised how sharp this gets and how well it holds an edge. If you have never used 3V this hard and thin, it is gonna blow your mind.
THESE ARE SOLD, THANK YOU
These knives are sharp.
This steel with this heat treat will support a fine thin edge, so this was taken down to .015" before sharpening and it was sharpened 15 degrees per side. This is acute and it cuts very well, but is still surprisingly durable. See video.
Some might consider this a tactical knife but the point is not reinforced and it is not shaped or balanced as a weapon, it is a hard working cutting tool, more of a big skinning knife or a woods knife. There is a pry in the tang.
The handle is ergonomically designed for a standard forward, reverse, saber and pinch grips for an average to relatively large hand. The tang is internally skeletonized. The scales are 3D sculpted CNC machined. The blade is made of 3/16 3V with a heat treat that has been optimized to maximize edge stability in rough use. Despite being relatively thin it is durable. You can baton with it.
A side effect of this heat treat is a higher percentage of free chromium, so although it is not stainless, it is nearly so.
Field Knife Specs:
3V, tested 61-62 HRC, .188 thick at ricasso
Total length 9.75
Blade length 4.625
Weight 8.0 oz
Grippy 3D machined scales in micarta or G10
Black oxide treated 18-8 stainless steel fasteners
Jared Corry sheaths are custom made for these knives and are well designed and well made. They can be worn vertical or horizontal and can be configured for left hand or right hand carry.
There are 5 of these in this sale, choose a color and I'll built it.
Rather than just take my word for it I made a video:
[video=youtube;1w1_WX_fNN8]https://www.youtube.com/watch?v=1w1_WX_fNN8[/video]
These are all field grade with a utility grade ground bevels and flats
$230 in micarta, black or brown (those are the two colors shown on the scales down at the bottom, they look multicolor because of the canvas)
$240 in solid color G10, black, OD green, blue
$250 in multi color G10, OD green, toxic green, brown, orange / black
There are limited numbers of the different scales material available. Availability is based upon first come first serve.
Includes a good kydex sheath.
Shipping in the USA is $5.
These knives are unusual because they are machined. I do this in my shop on industrial CNC machine tools. A WIP thread documenting my technique can be found here: http://www.bladeforums.com/forums/showthread.php/1048443
I take paypal, cash, check or MO.
Thanks for looking,
Nathan
Field Knife Specs:
Total length 9.75
Blade length 4.625
Weight 8.0 oz
Thanks for looking,
Nathan
