Five 3V HD Field Knives (THE N.A.S.K!), micarta, "Delta 3V"
Nathan the Machinist
KnifeMaker / Machinist / Evil Genius
Moderator
Feedback: +143 / =0 / -0
The Heavy Duty Field Knife was designed as a collaboration with Lorien Arnold. It is a well made, extremely durable, high performance large utility knife designed for comfortable extended rough use. The steel is Delta heat treat optimized Crucible CPM 3V at HRC 60-61 with very good edge retention and edge stability. You'll be surprised how sharp this gets and how well it holds an edge. If you have never used 3V like this, it is gonna blow your mind.
This steel does not need to be extremely thick to be nearly unbreakable, so this was taken down to .025" before sharpening and it was sharpened 20 degrees per side. It's a hard-use knife that cuts well.
They're hand ground after machining utilizing tooling and a process we developed to reproduce the complex bevel geometry found on a competition cutter with three world championships on it. We're developing that capability for another project but decided to include it on this new pattern. It incorporates a very shallow S grind that is mostly flat, but convex at the shoulder and behind the edge and includes an approximate 100" hollow grind in the center of the grind.
Some might consider this a tactical knife but the point is not reinforced and it is not shaped or balanced as a weapon. It is a hard working cutting tool that could be carried into combat, a big skinning knife and a hard use woods knife.
This is our most developed hand grip yet. It supports multiple positions to reduce fatigue and accommodate multiple tasks including a pinch grip and choil grip at the balance point for detail work, a regular hammer grip and saber grip and also a rearward 3 1/2 finger grip that allows you some extra length that makes it a surprisingly effective chopper for its size. The full size handle has been thoroughly tested and designed to minimize hand and arm fatigue during extended use.
Unnecessary weight is removed where possible and the tang is internally skeletonized for a neutral balance. The scales are 3D sculpted CNC machined. The blade is made of .220" 3V with a heat treat that has been optimized for edge durability in rough use. You can baton and pry with it. You might damage the edge if you set your mind to it, but the knife itself is practically unbreakable.
A side effect of this heat treat is a higher percentage of free chromium, so although it is not stainless, it is nearly so.
Specs:
CPM 3V, Delta heat treat, tested 60-61 HRC, .220" thick at ricasso
Total length 11.825"
Blade length 6.5"”
Weight 12.8 oz
Grippy 3D machined scales in micarta and Terotuf.
Black oxide treated 18-8 stainless steel fasteners
The price includes a very nice Mashed Cat sheath with TecLok. This is not a small knife so if you'd prefer a dangler sheath rather than a TecLok add $15 to substitute for a dangler sheath.
(If you're putting it on or in your pack or carrying it horizontal you might prefer the TecLok but if you're planning to carry it vertically on your belt you might prefer a dangler)
Tell me what scale option you choose and I'll build it. There are 5 knives available in this sale. The knives in the picture are not the knives you will receive. We are sharpening now and they will ship next week.
Due to limited quantities please limit one per post.
Price is:
$380 in black or natural canvas micarta
$390 in black linen micarta
$400 in OD green micarta
$410 in black (gray) Terotuf (ugly material that works awesome) on black micarta liner
There is some Hard Ebonite if you're interested, $410, inquire with Jo.
Price includes a good kydex sheath with TekLok. Change from TekLok to dangler add $15.
Shipping is $12
I take paypal, cash, check or MO.
Jo will contact you via PM or email on Sunday or Monday. Emails though BF often get lost in spam filters. If you don't hear from her by end of day Monday please contact Jo on her PM, or send us an email at carothersknives at g mail dought com
Five more HDFK here in one week!
Come by our forum this afternoon for a "Fun Friday" sale, an old-school EDC2, ground (not tumbled) wood scales, leather sheath, unlocks at 5:00 Eastern time
Come by our forum in two weeks for the Medium Chopper and Heavy Chopper pre-order
Thanks for looking,
Nathan
I’ll take the Light Gray one if it’s still available with dangler sheath. If it’s taken I’ll take what is still available.
I've changed my mind and I'm going to let someone else get one of these fine blades. I'm taking a chance on getting in line for the EDC2. Thanks!
Thank you so much Oyster and Casinostocks!! :)
What is the next step?? Do I wait for Jo to contact me?
Thanks again guys. Much appreciated!
Mrs. Jo Carothers will try to contact you and like the Gent above me has already stated, buying a membership (even the Basic one which I believe is still $10) on here will go a longer way to return the favor to the community plus making messaging between members a lot easier. Enjoy your HDFK :thumbsup:
