Hi Fred,
Thanks for offering the construction info:
1. How long and what is the diameter of that beast?
2. Im noticing a piece of square tube in the lower portion of the fire box. That looks like an excellent spot to set a longer blade for HT
3. What is the opening size of your forge? That looks like it would handle some intricate geometric shapes for ornamental stuff.
4. Why blown?
Kook and I were just talking to IG this afternoon about building a 36 forge for HT sword length objects, and the lower portion of your forge looks ideal for that task.
Thanks for the info.
Larry,
The forge body is 1/4"x12"x24"
I built the metal floor separately. It slides over apiece of angle iron that is welded to the rear of the forge under the round opening. See photo.
I did this for two reasons; so I can rebuild and reline the forge as needed and I thought it might be a good place to soak blades or maybe anneal. Kind of like a warmer oven
. If you take the face off the forge, you can slide the entire floor out. The floor is made
from 5/16" mild steel. The floor is six inches wide, behind the forge face plate and goes to four inches wide from the face plate to the end. When you put the face plate on, it holds the floor assembly in place.I ended up cutting the bricks to fit sideways, so they covered the entire floor. I have an external thermocouple for the
toaster oven so I can keep and eye on both temps at once.
The opening is 4"x4"
This forge has a K thermocouple that will be hooked to a pid controller.
It's a manual fuel/air system along side the one that runs through the pid controller. In a nut shell; low fan/ low gas[manual] and high fan/ high gas [controlled]. I will post more pics when I get this part completed.
As far as using a blower, my gas supply pressure runs around 12 lbs or so. If I add the blower I can turn the pressure to 5 or 6 lbs and produce the same temperatures.
I built this to do cans mostly. An occasional blade of some longer dimension, isn't out of the question; of course.
I hope this was of some help to you. Fred
