- Dec 6, 2013
Less than 25 feedback ships first
I reserve the right to deal with whomever i please
Thanks for looking!
Smith and Wesson 960- First production run 6 1/2" clip point CE satin blade, 3/16" stock. Has insertion marks from sheath. Has not been carried, used or sharpened. Comes with correct leather sheath-
Link to old post and pics: https://www.bladeforums.com/threads/strider-pp-3v-and-s-w-960.1507653/
Bud Nealy- Handrubbed 4" CPM-154 dual edged blade. The tip is reinforced. 8" OAL. Has not been carried, used or sharpened. Comes with MCS systems sheath. A magnet helps hold the blade in the sheath securely. No marks or scratches that i can see. Scales are g10-
Link to pics: http://www.bladeforums.com/threads/bud-nealy.1467867/
RHankins Fighter- 5 1/2" double edged blade, 52100 steel, .22" thick stock. OAL is 10 1/2". G10/CF scales, looks blue and green. Has not been carried, used or sharpened. Has scratches and marks due to handling and sheath insertion. Has crack on the scale on one side, hasn't spread, Hankins said he'd fix it if it became a problem. Comes with kydex sheath-
.Matthew Cody Hawkbill- 3 1/4" acid washed 3v blade,OAL is 7 3/4", liners are ti and the scales are coyote brown G10. Has been carried and used lightly, edge is original. No blade play, flicks open easily and is centered. Pocket clip is ti also-
Link to old post and Cody pics: http://www.bladeforums.com/threads/rhankins-fixed-blades-and-matthew-cody-3v-hawkbill.1505676/
Cold steel Tanto 13A- #0029. Satin blade, brass fittings(has patina, i have not cleaned it up).
Has not been used, carried or sharpened. Comes with original box but no sheath. It's in great shape and i'm ready to pass it along-
Southern Grind Bad Monkey- This is one of the early made models, complete with leather coozie, paracord bracelet and Bad monkey tool kit. Has a black DLC CE blade, peel ply CF, and the deep carry, short clip. Has been carried and handled, but the knife hides it well. Blade is slightly off-centered, no play in any direction. I am the original owner and the edge is original too-
Link to old post and pics: https://www.bladeforums.com/threads/spyderco-and-southern-grind.1505671/
Link to pics: http://www.bladeforums.com/threads/fairall-model-3.1476150/
1.Fairall Model #3- 3.75" hand rubbed s30v blade. Swedge has 1/4"ish sharpened at the tip. Tan and blue g10 scales, comes with a set of cocobolo scales too. Has extra hardware too.
Detent is on the lighter side. Requires a firm push of the thumb or flick of wrist to open via the flipper tab. It can also be opened with the dual thumb studs. Has been carried 4 times, cut arm hair to test the blade after i sharpened it. Fairall no longer makes knives, so this is definitely a collectible. Comes with soft carry case
TRADED
I'm pretty open to trades, let me know what you have
Thanks for looking!
TRADED
