Hi guys,
I have been looking through this forum for some time now and finally decided I would just create an account. After a few days using the search function to narrow my search I have hit a wall, hence the thread.
I am currently looking for a knife for a friend of mine who is deploying with a spec ops/delta/sof/snake eater type unit and on his previous deployment he mentioned that he broke his blade. As a gift for his wedding I am buying him a new one but am not exactly a knife expert.
What we aren't looking for are folders and multis as he is coming down with those. He needs a high quality knife that will not only serve as a CQC weapon but also utility tasks, such as digging, opening ammo crates etc.
After much deliberation and research (and his input of course) I have come up with a few points that should help narrow the search.
1. $500 budget
2. 6-7" blade length
3. convex or scandi grind
4. 0.25" thick (or greater)
5. Full tang
6. Slight recurve
7. secure sheath, easy draw
As I said above, not looking for folders or multis, and as I have seen numerous times on this forum comments about how it will spend most of the time on his belt or it will be stolen are not helpful. There are no unit restrictions, other than the obvious bright colours and crazy designs etc.
Sorry about the long post and all the parameters but when your friends life might depend on a knife at some point then you have to be specific.
Thanks in advance.
You mean something like this?
http://www.bladeforums.com/forums/s...-Battle-Grade-Tan-Canvas-Tanker-Grey-Brand-Ne
Just needs a sheath and it's not hard to find a kydex bender who could make a solid sheath in a week or two.
I'll add this. If you need a custom sheath built, I'll do it for free to help our men in uniform. All of my sheaths are tek lok and MOLLE compatible so he won't have any issues attaching it to his gear. I have a dozen or so sheaths in the hands of our troops now and a couple as far away as the USS Steatham in Japan. My son is a Military Enforcement Officer in the USCG on the USS Valiant currently doing drug interdictions in the Pacific. He uses my sheaths on his gear exclusively. I'd be honored to help out if needed. Here's one of his rigs. I took a Spyderco Enuff in H1 with yellow handles and switched the black handles out from the VG10 version so it would pass inspection from the chief. I then built the custom kydex rig and attached it to his Safariland duty holster. Rather than use eyelets, I used black oxide stainless and black brass Chicago screws so he can disassemble the sheath and clean it out if needed.[/IMG]
[/IMG]![]()
[/IMG]![]()
[/IMG]![]()
Bit of both really, as I don't know enough about knife steels I figured it was the best way to express the durability in layman's terms. Can anyone shed light on the best steel?
