See above for a custom that will survive anything thrown at it, made by a Veteran for someone still enlisted.
Swamp Rat Ratmandu
I have an old CarbonV bladed SRK and never liked it simply because the blade was ground at too obtuse an angle to cut wood or field dress small game the way I wanted. Maybe if was ground convex, like the A1 etc, it would have cut better and had more use. I just found that it acted like a semi sharp pry bar with the factory edge and I never wanted to spend the time grinding it back.
The biggest factor is going to be the sheath. Proper cold and cheap plastic is not a great combo. Charlie will set you up without a doubt. I'm guessing that most of the usage it will see will be general utility while on exercise, so a knife thought out for utility first will be the winner.
The only thing I'd toss into the mix as an additional thought would be something by LT Wright or a Fiddleback. Either way one thing I have leaned is that when wearing big mitts, there is no such thing as too much handle. If I was to move back to canada and was going to be playing in the woods, I might even consider a winter knife and a summer one, or get something I could add liners to the scales to bulk up. But your needs (and fingers) may vary.
I think a smaller blade would be better, I have read over the years from active duty troops that smaller is better for their needs, depending on what you do of course, but worth considering. +1 on the Falkniven F1. ESEE3 or 4 also come 440C stainless, and I think where I just saw where new handles can be attached to the 3 to give it a little bit longer handle length. If you can find them, the 3 came in D2. If larger, the ESEE 6 fills the bill, although in 1095.
More expensive, but I have always liked some of the knives from Martin Tactical Knives. Lastly, what about a multi tool? Let us know what you decide.
That blade reminds me alot of a Perrin Street Beat. The Street Beat is one of my favourite fixed blades. Spyderco version's sheath seems to dull the blade though.
Slightly off topic, gentlemen, I hope you will forgive. It's a method of carry diversion.
I must ask you, CM, because I know you've done a lot of experimenting. For civvy use, you seem to use the same set up, right?
I found myself strapped up in safety belts in a bus on a wild ride up a mountainside with incredibly tiny seats and it occurred to me the only pocket I could get to quickly if the even the bus went down the ravine and I survived was the breast pocket, where I decided to put my rescue tool (glass breaker, serrated blade etc).
Bottom line is, I wonder about the offhand i.e. left breast inverted carry. For small knives like the SRK, it may not be that bad, unless there's something else that should be there that I don't know about. Or some disadvantage I don't know about or haven't thought through.
