Thanks Alberta.
The Gransfors is just so sharp, and has such great penetration due to the weight, and geometry of the grind. - don't know if there is an equal in the knife field..
... fixed blades are simply not as efficient as axes for chopping, or even your hatchet.
If you post this question over in the Himalayan Imports Cantina, you should get some helpful and informative responses.Is their a Fixed blade that will chop as well as my Gransfors Bruks wildlife hatchet?Primarily I use the Gransfors to cut down saplings that I make staffs/canes out of. At max they are about 2-3 inches in diameter.
Maybe a kukri? But fixed blades are simply not as efficient as axes for chopping, or even your hatchet.
