- Jul 31, 2015
It's just a common countersink angle.Thanks Kevin ! I knew it , but that 82 degree confused me .For what is used that strange angle ?
Ether 90 or 82 will work fine.Thanks Kevin ! I knew it , but that 82 degree confused me .For what is used that strange angle ?
I believe that's the normal drill bit angle
Drill bits are generally 118 or 135 degrees.
Countersinks are 82 or 90 degrees. 82 degrees to match flat head cap screws and 90 degrees because hole chamfers are generally called out to be 45 degrees.
This is what I plan to finish this days.Two connecting rods and little work on lathe , yellow is small axial needle bearing.Left side will be fixed ,on right side large screw ................It should work ............... I think
How do you modify the screws to press and flare the tubing? Are you using the side of the screw with the threads on it or the screw head side? ThanksI use a vice with two flat head screws in each end of the tubes and a small dab of oil to prevent splitting the tubes. After that I finish them off with an anvil and punch both turned to match the 82 degree countersink I use. A place I used to work at had a small hydraulic press that with some dies would be perfect for setting the flares. I think it was an Enerpac brand. A larger size arbor press could do it too with the proper dies.
82 degree countersink cutting tools are the most common in North America because it's the angle of countersink head screws.Thanks Kevin ! I knew it , but that 82 degree confused me .For what is used that strange angle ?
not to be a bad guy here but i always was told it is 60 degree for wood screws, 90 for metric machine screws, 82 for SAE (US) machine screws,82 degrees is most common for wood screws. 100 degrees is what many aerospace fasteners use for better hold with thinner metals for structural fasteners. Wood screws are different than machine screws, usually 82 then machine screws can be from 90-110 degrees.
Do you have any pics of what yours look like? Do you just hammer the punch one side at a time? Are you using a countersink hole?You guys sure overthink things. I just use a punch to flare them.
I guess if I did a lot of flared rivets, I might make something to make the job quicker.
