I think I am going to pick up a 4Sevens Neutral White Quark AA2 ... but not sure if I should go with the Cree XM-L Neutral-white or the Cree XP-G Neutral-White. Looks like XM-L is better for the bright end and the XP-G is better for the low end. Does anyone have any guidance in deciding between these two?
I haven't really talked about what I want to use it for since I want it to be able to do just about everything that a flashlight should be able to do. Its immediate use will be around camp, hiking around at night, etc. Since I'd really like it to be able to last forever in case of an emergency, however, I guess I am probably leaning towards the XP-G. Not sure if there are other featuers that matter other than just whether you want brighter or longer lasting.
I think I might also pick up that lighthound/balder as an affordable back up.
I think you will be happy with the 4Sevens. It has a 120 month warranty, the last time I checked.
I'd seriously consider Energizer Ultimate Lithium cells to power it. Spendy batts but they won't leak in your light.
You've not told us your intentions for the light, so only you know the features that may be of interest. To answer your question, though, Fenix and 4sevens lights are good solid highly respected lights whether you're spending $20 or $100.
I don't think anyone has mentioned it yet, but these are LED lights. They do not use bulbs. LEDs (for the most part) cannot be replaced, because they never need replacing. They are virtually unbreakable, and they don't burn out.
