4) HaikeLite MT07s XHP70.2 NW
Emitter: XHP70.2 (4800k-ish neutral white).
Purchased new when it first came out. Excellent condition. Only visible wear is 2 scratches on the antireflective coating on the inside of the lens, came from factory like that. Does not affect the beam. Lost the box but includes tripod lanyard/sling carry ring and 4 matched Sanyo/Panasonic NCR18650GA 3500mAh button top batteries. Loosen body from head to mechanically lockout light.
Modes
From off: Single press to turn on, single press to turn off
While on: Press and hold to cycle through low, medium 1, medium 2, high
While on or off: Double press goes to Turbo
From Turbo: Double press goes to Strobe
While off: Press and hold to access Moonlight
Includes: Light, tripod lanyard/sling carry ring, 4 batteries.
5) Fireflies PL47 SST20 4000k
Emitter: SST20 (4000k neutral white).
Purchased new when it first came out. Excellent condition. Magnetic tailcap. Fully programmable, see flowchart.
Includes: Light, box, 21700 battery, 18650 battery spacer, spare orings, pocket clip, headlamp holder.. not the best from what I've seen in videos. I believe the pocket clip is needed to be on to help hold it in place.
6) Armytek Tierra C1 Pro XM-L2 Hi CRI
Emitter: XM-L2 (3000K warm white).
Purchased new and never carried. Can use either a 18350, 16340, or CR123a battery.
Modes/UI Manual
https://www.dropbox.com/s/1z942id39yf31g0/Tiara_Pro_v2_EN.pdf?dl=1
Includes: box, manual, flat and magnetic tailcaps, head-strap, lanyard, pocket clip and spare o-rings.
7) Acebeam TK16 OSRAM CW
Emitter: OSRAM (6000K cool white).
Purchased new and carried lightly. I removed the pocket clip to reorientate it the other way, as a result there are 2 small marks on the body visible in the photo as it was hard to take off. This is a triple emitter light and because of the emitters and optic used by Acebeam, this light will have some rings visible. Pretty good throw for it's size and being a triple. Uses a tail e-switch.
Modes
While on: Press and hold to cycle through low, medium, high
While on or off: Triple press goes to Strobe
While off: Press and hold coming to Moonlight, and continue holding to electronically lock the light out. Press and hold to unlock the light.
Includes: Box, battery, instructions, warranty card, spare o-rgins and boot cover.
8) Keychain Bundle (Foursevens Mini MkII, Olight i3 EOS, Astrolux A01)
Emitter: various
XM-L2 Cool white. Turbo is rated at 1000 lumens. Rode my keychain for a long time. Semi-programmable - currently set to Moonlight, low, medium, high. Mode switching get's some getting used to as it sometimes skips and is not consistent. This was a common complaint at the time of it's release. Includes box, instructions, pocket clip, keychain attachment clip (add your own split ring) and a AWT 16340 battery.
Olight i3 EOS
Cool white, I belive an XP-G2. Also rode my keychain for a long time. Needs an AAA battery and split ring. UI is medium, high, moonlight with no memory. Going through the mode cycle past 2 times in a row will access strobe.
Astrolux A01
Neutral White, Nichia emitter (I forgot which variant). Was a backup in my bag. Needs a battery and split ring. UI is low, medium, high with no memory. Going through the mode cycle past 2 times in a row will access strobe.
