Flashlights: Fivemega / Convoy / Fenix / Acebeam / HaikeLite / Armytek/Oveready
Feedback: +95 / =0 / -0
Sale Terms:
  • US/US territory shipping only
  • First Class shipping 1-6
  • Priority Mail shipping 7-8
  • Paypal Purchase of Goods Option (no gift payments please)
  • I reserve the right to refuse sale at my discretion
  • No trades/No Proxy Buying
1) Fivemega Gray Surefire 6P P60 Host relisted
2) Convoy M2vn Oslon W2 (modified by Vinhnguyen54) relisted
3) Fenix BC30 V1 relisted
4) Acebeam TK16 Triple NW [Sold to Joseph Milton] $40
5) HaikeLite MT07s XHP70.2 NW relisted
6) Armytek Tierra C1 Pro XM-L2 Hi CRI [Sold to Joseph Milton] $55
7) Acebeam K30-GT SBT-90 GEN2 with 3 batteries [Sold to Joseph Milton] $150
8) Oveready Triple v5 E/Scout Head XPL 3000K +Amber with Malkoff body relisted
P60 Host. C Head, C Tail with McClicky switch. Body is bored for an 18650 battery (non-protected, protected cells may not fit). Tailcap has a slight imperfection as it has a small "ding/dent." This was present before the anodization process as it is underneath the gray anodization.
This was the work completed by Fivemega:
  • Completely removed and deanodized to bare metal.
  • Bored out to 18.77mm to fit 3400mAh 18650
  • Add milling holes on knurling area for better grip and unique look.
  • Masked all threads with special tape.
  • Sand blast mid section of body, tail cap and head. This is necessary for matte gray look.
  • Type III natural hard anodized body, head and tail cap. (Avg. 2 mill Buildup)
  • Install new black switch boot, new McClicky switch with FM switch retainer.
  • Add double oring on tail side.
Emitters: OSRAM OSLON White2 (6500K cool white).
This was modified by Vinhnguyen54 @ CPF and direct from him. Strike bezel was heat treated and Vinh added his FS54 forward clicky switch. Uses the VN4 firmware. Uses an 18650 battery. Nice clean and white beam with good throw. Approximately 1000 lumens.
Includes: Build card and programming sheet.
3) Fenix BC30 V1
Emitters: XM-L2 T6 (cool side of neutral white).
This is version 1 that has the wired remote switch to hit turbo. Used to use when I would do night cycling, though I no longer ride at night due to some close calls.
Includes: 2 protected Keeppower 18650 batteries, remote switch, bicycle mount, box.
4) Acebeam TK16 Triple NW (top light and light to the left in each photo, bezel up carry)
Emitter: SST-20 (4000K neutral white).
Purchased new and never carried. Still has protective film over lens.
Modes
From off: Single press to turn on, single press to turn off
While on: Press and hold to cycle through low, medium, high
While on or off: Double press goes to Turbo
While on or off: Triple press goes to Strobe
While off: Press and hold to access Moonlight
While off: Press and hold coming to Moonlight, and continue holding to electronically lock the light out. Press and hold to unlock the light.
Includes: Box, 16340 battery, instructions, warranty card, spare o-rings and boot cover.
Emitter: XHP70.2 (4800k-ish neutral white).
Purchased new when it first came out. Excellent condition. Only visible wear is 2 scratches on the antireflective coating on the inside of the lens, came from factory like that. Does not affect the beam.
Modes
While on: Press and hold to cycle through low, medium 1, medium 2, high
From Turbo: Double press goes to Strobe
Includes: Light, tripod lanyard/sling carry ring.
Emitter: XM-L2 (3000K warm white).
Purchased new and never carried. Can use either a 18350, 16340, or CR123a battery.
Modes/UI Manual
https://www.dropbox.com/s/1z942id39yf31g0/Tiara_Pro_v2_EN.pdf?dl=1
Includes: box, manual, flat and magnetic tailcaps, head-strap, lanyard, pocket clip and spare o-rings.
Emitter: SBT-90 GEN2 (cool white).
Purchased new and never carried. Throws like a champ and very bright!! Comes with 3 matched 18650 Acebeam ARC18650H-310A IMR 18650 3100mAh 20A Protected High Discharge Button Top. The box it comes in has a little ding/dent in it - this was how it was received.
Modes
While on: Press and hold to cycle through low, medium1, medium2, high
While off in lockout: Fast click 10 times to set Turbo from low to high, or high to low. Press and hold to unlock the light.
Includes: box, manual, handle grip, lanyard install ring, o-rings, and 3 18650 batteries.
Emitter: XP-L (3000K warm white with Amber secondary).
Purchased new and never carried. Comes on an unshrouded Malkoff MDC 18650 to E-Series Body and includes a LG MJ1 3500mAh 18650 battery.
Programming can be done via a web video interface through Lux-RC. Link and instructions will be sent upon purchase.
Acebeam TK16 Triple NW and K30-GT, and Armytek Tierra C1 are all sold to Joseph Milton. Thank you!!
