- Apr 9, 2004
Yeah Rob, I'd sure could use one of those.Dan Gray said:Rob when you going to start making and selling these![]()
edited to add
str take a peek here
http://www.beaumontmetalworks.com/rotaryplaten.html
Scott
America has reached 250 years, and I am grateful to be here, in the best country in the world. Thank every one of you who helps make this country a better place, those who have gone before and risked it all, and those who've paid the ultimate price to make the United States what we are today.
edited to add
Razorback - Knives said:Yeah Rob, I'd sure could use one of those.![]()
Scott
welcome back LaurenceRHINOKNIVES said:Hi, Rob and everyone else! I have taken a breather from knives for a about two years and did a bunch of stuff on Ebay, mostly militria, soviet "stuff". well Mr. Frink! did you every finish a working rotary palten for the HARDCORE grinder? You sent me one in the early stages of development. but it was a little off center if I remember right. I would be interested in any new developments! and how you line of Knifemaking stuff has grown! Laurence
Yep...that's the basic problem.Hey Rob!
Correct me if I'm wrong, but the reaso this isn't available for Square Wheels is due to the amount of offset required, correct? If that's the case, it can't be too big of a deal to replace the cast armature that the SW uses to mount its contact wheels or platen, right? Judging by the look of your Bader arm, all that was necessary was to reduce the arm thickness at the rotary platen mounting point enough to compensate for it's offset... couldn't the same be done by making a new arm that utilized the existing mounting bolts on the SW setup?
haha you remember my old handleRHINOKNIVES said:Hi, Rob and Graymaker. good to hear from you guys! has anyone heard from Bruce Evans? did he get washed away? I emailed him and have not heard a thing back. Also who is selling that pryrex type glass to be used on the palten for flat grinding. I need a few pieces to get rolling again. Laurence
Donna has a little adventure too but I'll let him tell that if he wants to..
rfrink said:Yep...that's the basic problem.
Nope can't do it, but I will say it don't involve swim wearrfrink said:Oh! Pleez Tell!!!
rfrink said:Donna in swim wear was always nice!
Donna....not in swim wear? Well, that sounds pretty nice as well.
(respectfully kidding, of course)
I missed seeing Bruce and Donna at the Blade Show this year. In the past, they usually stop by to say hello.
Rob, looks awesome. I know what you mean about the platen. Having the rubber belt as a slight cushion would be very nice to grind on indeed. My old home made disc sander had rubber for my backing on the discs and was quite nice to grind on.rfrink said:This is the result of a discussion a few weeks ago in The Custom Knife Forum about flat grinding.....
The idea was originated by Ken Onion about a "rotary Platen" to eliminate the annoying thump and bump from tradition platen grinders. Inspired and encouraged by Ken and others, I built a prototype and tried it out today.
The basic idea is to use a secondary belt like a Tank track which rotates with the abrasive belt. By adjusting the tension on the secondary belt, you can effectively controll the membrane stiffness to appraoch a flat grind.
I started with an industry standard V-ribbed belt...type J, commonly found in machine tools and readily available from power transmission dealers.
With mini-"V" ribs on the back side, these belts ride on ribbed rollers and are locked in place side to side as the run. The abrasive belt tracks beautifully....and can be steered from side to side while the secondary belt remains in place.
I made the attachmnet with an optional center roller to add more support and to reduce deflection,....for flatter grinds.
The tension is precisely adjusted with a sliding bracket and jack screw.
I was amazed with the stiffness of the taught belt....with out the center roller.......and even more excited when I put the center roller on.
I just finished it today and I've only used it for about a 1/2 hr. I was most suprised by the whisper quite sound when I first turned it on. No belt rubbing across a platen. Then when I started grinding on it....it felt just like a contact wheel![]()
Even though it has hardly been tested.....I couldn't contain my excitement and enthusiasm to share it.
I have another in process one with a different type of belt.
So, whatta ya think...? feasible, waste of time? any ideas for improvement. Would you like to see something different...?
I think it is remarkable! I am not the author of this wonderful idea.....I'm just a regular working smuck that built it. Credit for the idea goes to Ken Onion.
Thanks Ken!
Sincerely,
Rob
