In my experience it doesn't matter. It all comes down to blade thickness, edge thickness behind the bevel, grind angle etc. Blade geometry is key. I have FFG's that out slice some of my hollows and visa versa. I don't have any full convex knives to compare to, it seems to be the trending grind out there right now. No wait I do. I have a vic executive (the medium sized blade) I have full convexed from sharpening with sandpaper over time. I don't think I've ever noticed a difference between it and a factory. So back to my original statement. The grind does not matter, the blade geometry does. Even if you had 2 knives with the same edge angle blade stock and everything, I don't think you'd be able to tell a difference in grinds in normal edc. When you get to specific uses then there are grinds that are better suited, such as a chisel for planing or a high deep hollow for shaving for example. For edc though it does not matter what anyone says, a hollow will do just as good as a convex or a FFG. They all slice paper or will open a box or pop a zip tie and cut a stray thread if the edge is sharp and thin.
