- Apr 3, 2009
What's the best way to flat grind a blade and get it even :
Long term a jig wont get you where you want to be. You want to simply grab any blade no matter blade thickness, height or shape and just grind away. IN MY EXPERIENCE a jig will only slow you down and lengthen the learning curve.
Sorry fellas, just my experience. Kit told me starting out, you want to grab and grind......grab another, and grind. Fussing with jigs can work but where the original poster wants to be isnt dealing with jigs.
Marking all the flats with dykem layout die to show where your grinding and not moving that grind line UP untill its flat and where youw ant it is the second step after marking the center and grinding to the center lines with about a 45 degree angle.
USe 36 grit belts and grind side to side slow but even and let the belt do the work. NOT pressure and speed.
Clean up with 60 grt and really get about 1/3rd where you want to be with 120 grit.
This is where I heat treat.
Go back to 60 grit to 400 grit.
Its just practice and burnt fingers to get where you want to be Roger:thumbup::thumbup:
