Here's what works best for me.
1. Remove graphite crap (I see you've done that)
2. Go to
Ellis Custom Knifeworks and by the 2"x9" ceramic platen liner.
3. Get some JB Weld and when you receive the ceramic platen, mix the JB Weld and spread liberally on the platen. Clamp lightly (just enough to hold it on or you'll crack it!!!) and let sit for 24 hours. Check it once in awhile to ensure it hasn't slipped. You can remove the metal platen for the process. It makes it easier to clamp it down on a flat surface.
4. When you grind your flats, get a welder's magnet like this
one and cover the long flat face of the magnet with some blue painter's tape to make cleaning it easier. This will allow you to peel the tape off when it gets too built up with grindings, rust, etc. Then just replace the tape. place the flat face on the magnet and carefully hold up to the platen. Yes, use sharp fresh belts. You will develop a feel for when you are flat on the platen. DO NOT PRESS HARD! This will cause the piece to bump and pull causing more unevenness. You will get dips also that are a b***h to get out. Yes, I've done this. It sucks!
Feel free to email me if you have any more questions. The Grizz is a love / hate relationship. I have a Bader II that still have to hook up but honestly, I've gotten used to my Grizz over 2 years and don't hate it nearly as much as I used to.
