- Jun 21, 2007
I wonder if Cliff Stamp will respond.
I like flat grinds and convex grinds a lot, but I use folders with hollow grinds, too (like the Spyderco Endura or Buck 110).
For fixed blades, I wouldn't trust a hollow grind very much, unless it was a small pocket fixed blade which will not be used too hard.
I like hollow ground on a hunting knife. It gives you the thinnest edge for cutting sticky sinewy material. It also works well on stiffer material if you are shaving or whittling material off the surface. If works well on rope.
The scales tip towards a full flat grind when you cut stiff material. For example I would rather use a thin flat ground blade to cut through a credit card than a similar hollow ground blade. In hard material the back shoulder of the hollow tends to bind.
That's it!!!!
When I get home I am selling all my inferior Doziers!!!
How could Bob have fooled so many of us.. Thank god I found this thread.
I have a 1095 5" "bushcraft" knife with a hollow grind and it out performs any knife in the woods I have owned. The edge lasts very long. I can split wood for a fire, lots of it for a couple days and still be able to make fine feathers, cut notches, make tent stakes and so on. A couple weeks ago I batoned the knottiest piece of twisted pine I ever came across and the blade had so much flex in it, it looked like The leaf spring on my ranger if I were to over load it by 1,000 pounds. If I had my camera I would have taken a pic. Blade got pounded the rest of the way through and came out straight as an arrow. I was more worried about a scale breaking or popping off from the flex than the blade. When I got done I feathered it up and made a fire. If I expect one knife to do many tasks like baton, feather and butcher the hollow grind with a good carbon steel is the way for me. If a blade bends or breaks with a hollow grind during heavy work then the knife was made for show or taking pictures of or just doing cardboard cutting contests. A knife made to do work will not, no matter the grind.
My old EDC was a flat ground SOG and it was great for straight cuts, it was not nimble at all in any media I would cut. My new EDC I specifically looked for a hollow grind and I can cut circles in cardboard now if I need to, it also does not wedge in the cardboard as much and slices through much easier than a flat grind ever did. The hollow grind on my new EDC can also do duty in the woods for lighter work like tent stakes, notches and feathers if I want now. The old flat grind would wedge in the deeper you got making it hard for the edge to do its job, no matter how sharp it was. The hollow also cuts thick rope better when you make a loop and run the blade on the inside, same scenario, the flat grind wedges in easier and makes the cut difficult as you tighten that rope up against the grind that's getting thicker the more you cut.
Opening boxes, cutting tape or making a YouTube video slicing stacks of cardboard in straight lines a flat will do fine. Doing tasks in the woods, butchering, and EDC tasks the hollow grind is a far better option if you use the knife for a variety of tasks. Just my observation over the decades.
Buck 110 by Pinnah, on Flickrthe flat ground is generally considered to be much more difficult to execute correctly.colbalt hits it on the head, not one of the competition knives used in contests is hollow ground. it was right in front of us but cobalt saw through to the entirely correct answer. Gary Randall told my brother the hardest grind to execute was the flat.certainly the man whom is in charge of randall knives knows something aboput knife bevels. in addition most good german knives imported to u.s. had flat grinds. nearly all the Pumas Except the earl,duke,prince;& empourer were flat grinds, all my weidmanshiels had flat grinds. flat grinds cut better & are stronger.
I'm bringing this thread back from the dead. Most of my folders have been sabre or full flat grind. I have a Cold Steel American Lawman, which uses a high hollow grind, on the way. What are your thoughts now on flat versus hollow? For thise that prefer hollow, do you prefer a high hollow?
The reality is that sabre-grind hollow ground blades are always superior for normal use, if only because they remove metal exactly in the place where it is the most difficult to remove neatly when you sharpen... You have to remove metal away up from the edge first in all other knives, and that is exactly where you make mistakes and put scratches on the sides...: Isn't it easier to have this metal off to begin with? Just above the edge, without scratching the side...
The other advantage of hollow grinds is that, by virtue of being saber ground, you get way more mass above the edge than on the typically distal tapered flat ground blade: This means it chops deeper with less effort (below maximum effort is the way you should chop safely in actual use).
