- Aug 2, 2010
I have a question .. I been meaning to ask this for a while but havn't gotten around to it till now..
After forging a "full tang" blade, how do you guys (who forge knives with forged finishes) go about making to tang perfectly flat so the scales will lay against them perfectly, but without grinding off the forge/scale finish on the ricasso just in front of the scales?
I have seen guys taper tangs "after" forging a blade and be able get it flat to attach scales to it while being able to leave the ricasso untouched, even with scales that have fronts that are a bit rounded or curve back in some way or etc. This makes the option of just sanding right up to when the front of the scales would end in a straight line not very helpful, cause if there were some curve to the front of the scales, there would be gaps where the front of the curved scales would go past that "straight line" that was established by grinding the tang flat to where it terminates with a straight line from spine to bottom of the handle.
So I want to know what methods you guys use, the tang doesnt have to be tapered, although it would be nice to know how to achive this look that way as well. I just want to be able to get my tang nice an flat to attach the scales but without removing any of the forge finish from the ricasso just in from of the scales..
I dont have a disc grinder btw, but I do have a 2x72 with a ceramic platen.
Please help, this problem has been bugging the crap out of me forever! To help understand what I mean if you don't, a great example of what I'm taking about would be a lot of the knives made by "Claudio Sobral from CAS Knives." He does some great forge finish/texture work while at the same time being able to get some pretty damn thin tapered tangs while leaving all the texture in front of the scales untouched along with a lot of his scales fronts being curved. Again, the tang doesnt have to be tapered, but it sure would be nice to know how it's done that way as well, if at all possible for ya guys to explain.
Thanks for any and all help in advance! There has be this monkey on my back, and once I figure out how to do this, he should be gone
-Paul
www.youtube.com/Lsubslimed
-Paul
