Hi Guys,
I have been making flippers and I am looking to increase the holding strength of the detent to make the flipping action better. My method till now is by just bending the lock a bit stronger, but i am finding this to be unsatisfactory with either the blade action being a bit stiff, and if i bend it too strong the blade goes slightly off center. After a bit of research I see that a some guys are flattening the top of the detent a little, which seems to increase the holding ability of the detent making it better for flippers.
Any advise on flattening the ball? (must i set as normal and then just grind the top flat, open hole size a bit in blade, etc )
Any other suggestions to get a better flipping action.
(My method at the moment : I am using 1/16balls and setting the detent by drilling right through the liner into the blade in the closed position using 1,4mm (#54) Drill. I use feeler gauge to check the depth between liner and blade and then press ball into place with that measurement)
Thanks
Thanks
