- Aug 12, 2006
Matt, thank you so much for stopping by and giving us your insight! I've read your posts a couple of times and took a lot away from it with the most important part being the contact (ball in hole) meeting at 90 degrees. Of course this makes complete sense and gave me the "aha!" moment. I, for one, am going to order some carbide drill bits between .050 and .080 and gradually open up the hole until the ball drops in to that sweet spot.
My only question to you, Matt, is could you please explain how you "back cut" the detent hole? And is it even necessary if the hole is large enough to already accommodate the ball if the offset between the two is still in place enough to hold the tension without slop?
The tricky part would seem to be opening up the hole just enough to accommodate the ball as explained above but not enough to lose the tension and cause play. If starting with enough offset there should be enough wiggle room to experiment.
Mark
Mark
